Ir para o conteúdo principal
Dell Alienware 13 R2 Solid-State Drive Replacement
O que você precisa
  1. Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Screws: passo 1, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Screws: passo 1, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  2. Dell Alienware 13 R2 Solid-State Drive Replacement, Peel off Computer Base Tabs: passo 2, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Peel off Computer Base Tabs: passo 2, imagem 2 %32
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  3. Dell Alienware 13 R2 Solid-State Drive Replacement, Disconnecting the Solid-State Drive Cable: passo 3, imagem 1 %32
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  4. Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Solid-State Drive: passo 4, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Removing the Solid-State Drive: passo 4, imagem 2 %32
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  5. Dell Alienware 13 R2 Solid-State Drive Replacement, Lifting the Solid-State Assembly: passo 5, imagem 1 %32
    • Lift the solid-state drive assembly off the computer base.
  6. Dell Alienware 13 R2 Solid-State Drive Replacement, Remove the Screw: passo 6, imagem 1 %32
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  7. Dell Alienware 13 R2 Solid-State Drive Replacement, Lift the Solid-State Assembly.: passo 7, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Lift the Solid-State Assembly.: passo 7, imagem 2 %32
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  8. Dell Alienware 13 R2 Solid-State Drive Replacement, The New Solid-State Drive: passo 8, imagem 1 %32
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  9. Dell Alienware 13 R2 Solid-State Drive Replacement, Screw Replacement: passo 9, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Screw Replacement: passo 9, imagem 2 %32
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  10. Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screws: passo 10, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screws: passo 10, imagem 2 %32
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  11. Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: passo 11, imagem 1 %32
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Solid-State Drive Replacement, Connect the Cable to the System Board: passo 12, imagem 1 %32
    • Connect the solid-state drive cable to the system board.
  13. Dell Alienware 13 R2 Solid-State Drive Replacement, Align the Screw Holes: passo 13, imagem 1 %32
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  14. Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: passo 14, imagem 1 %32 Dell Alienware 13 R2 Solid-State Drive Replacement, Replace the Screws: passo 14, imagem 2 %32
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 265
