Ir para o conteúdo principal
Dell Alienware 13 R2 Memory Modules Replacement
  1. Dell Alienware 13 R2 Memory Modules Replacement, Popping up the Memory Module: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Alienware 13 R2 Memory Modules Replacement, Removing the Memory Module: passo 2, imagem 1 %32
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Alienware 13 R2 Memory Modules Replacement, Align the notches: passo 3, imagem 1 %32
    • Using the new memory module, align the notch on the memory module with the tab on the memory-module slot.
  4. Dell Alienware 13 R2 Memory Modules Replacement, Sliding the Memory Module: passo 4, imagem 1 %32 Dell Alienware 13 R2 Memory Modules Replacement, Sliding the Memory Module: passo 4, imagem 2 %32
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Conclusão
Terrence15
Membro desde: 12/18/17
79.121 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.985 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 122
