Ir para o conteúdo principal
Dell Alienware 13 R2 Display Assembly Replacement
O que você precisa
  1. Dell Alienware 13 R2 Display Assembly Replacement, Turning Over the PC: passo 1, imagem 1 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
    • Close the display and turn the computer over.
  2. Dell Alienware 13 R2 Display Assembly Replacement, Loosen the screws: passo 2, imagem 1 %32
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Dell Alienware 13 R2 Display Assembly Replacement, Releasing the Tabs: passo 3, imagem 1 %32
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Dell Alienware 13 R2 Display Assembly Replacement, Disconnecting the Battery Cable: passo 4, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Disconnecting the Battery Cable: passo 4, imagem 2 %32
    • Disconnect the battery cable from the battery-cable connector.
    • Turn the computer over.
  5. Dell Alienware 13 R2 Display Assembly Replacement, Power Button: passo 5, imagem 1 %32
    • Press and hold the power button for 5 seconds to ground the system board.
    • Connect the battery cable to the battery-cable connector.
  6. Dell Alienware 13 R2 Display Assembly Replacement, Aligning the tabs: passo 7, imagem 1 %32
    • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
  7. Dell Alienware 13 R2 Display Assembly Replacement, Tighten the screws: passo 8, imagem 1 %32
    • Tighten the captive screws that secure the base panel to the computer base.
  8. Dell Alienware 13 R2 Display Assembly Replacement, Removing the Screws: passo 9, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Removing the Screws: passo 9, imagem 2 %32
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  9. Dell Alienware 13 R2 Display Assembly Replacement, Peel off Computer Base Tabs: passo 10, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Peel off Computer Base Tabs: passo 10, imagem 2 %32
    • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
  10. Dell Alienware 13 R2 Display Assembly Replacement, Disconnecting the Solid-State Drive Cable: passo 11, imagem 1 %32
    • Using the pull tab, disconnect the solid-state drive cable from the system board.
  11. Dell Alienware 13 R2 Display Assembly Replacement, Removing the Solid-State Drive: passo 12, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Removing the Solid-State Drive: passo 12, imagem 2 %32
    • Remove the screws that secure the solid-state drive assembly to the computer base.
  12. Dell Alienware 13 R2 Display Assembly Replacement, Lifting the Solid-State Assembly: passo 13, imagem 1 %32
    • Lift the solid-state drive assembly off the computer base.
  13. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screw: passo 14, imagem 1 %32
    • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
  14. Dell Alienware 13 R2 Display Assembly Replacement, Lift the Solid-State Assembly.: passo 15, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Lift the Solid-State Assembly.: passo 15, imagem 2 %32
    • Slide and lift the solid-state drive off the solid-state drive assembly.
  15. Dell Alienware 13 R2 Display Assembly Replacement, The New Solid-State Drive: passo 16, imagem 1 %32
    • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
  16. Dell Alienware 13 R2 Display Assembly Replacement, Screw Replacement: passo 17, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Screw Replacement: passo 17, imagem 2 %32
    • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
  17. Dell Alienware 13 R2 Display Assembly Replacement, Align the Screws: passo 18, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Align the Screws: passo 18, imagem 2 %32
    • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
  18. Dell Alienware 13 R2 Display Assembly Replacement, Replace the Screws: passo 19, imagem 1 %32
    • Replace the screws that secure the solid-state drive assembly to the computer base.
  19. Dell Alienware 13 R2 Display Assembly Replacement, Connect the Cable to the System Board: passo 20, imagem 1 %32
    • Connect the solid-state drive cable to the system board.
  20. Dell Alienware 13 R2 Display Assembly Replacement, Align the Screw Holes: passo 21, imagem 1 %32
    • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
  21. Dell Alienware 13 R2 Display Assembly Replacement, Replace the Screws: passo 22, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Replace the Screws: passo 22, imagem 2 %32
    • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
  22. Dell Alienware 13 R2 Display Assembly Replacement, Lifting the Latches: passo 23, imagem 1 %32
    • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
  23. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screws: passo 24, imagem 1 %32
    • Remove the screws that secure the palm-rest assembly to the computer base.
  24. Dell Alienware 13 R2 Display Assembly Replacement, Lift the Computer Base: passo 25, imagem 1 %32
    • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
    • Turn the computer over and open the display as far as possible.
  25. Dell Alienware 13 R2 Display Assembly Replacement, Prying the Palm-Rest Assembly: passo 27, imagem 1 %32
    • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
  26. Dell Alienware 13 R2 Display Assembly Replacement, Lift the Palm-Rest Assembly: passo 28, imagem 1 %32
    • Gently lift the palm-rest assembly and turn it over.
  27. Dell Alienware 13 R2 Display Assembly Replacement, Lift the Connector Latch: passo 29, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Lift the Connector Latch: passo 29, imagem 2 %32
    • Lift the connector latch and disconnect the power-button board cable from the system board.
  28. Dell Alienware 13 R2 Display Assembly Replacement, Lift the Palm-Rest Assembly: passo 30, imagem 1 %32
    • Lift the palm-rest assembly off the computer base.
  29. Dell Alienware 13 R2 Display Assembly Replacement, Removing: passo 31, imagem 1 %32
    • Remove the keyboard.
    • Remove the power-button board.
    • Remove the status-light board.
    • Remove the Touchpad.
    • Replace the touchpad.
    • Replace the status-light board.
    • Replace the power-button board.
    • Replace the keyboard.
    • Connect the power-button board cable to the system board.
  30. Dell Alienware 13 R2 Display Assembly Replacement, Align the Palm-Rest Assembly: passo 34, imagem 1 %32
    • Align the palm-rest assembly on the computer base and snap it into place.
    • Replace the screws that secure the palm-rest assembly to the computer base.
    • Connect the keyboard cable and the keyboard-backlight cable to the system board.
  31. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screws: passo 39, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screws: passo 39, imagem 2 %32
    • Remove the screws that secure the hinge caps to the display hinges.
  32. Dell Alienware 13 R2 Display Assembly Replacement, Lifting the Hinge Caps: passo 40, imagem 1 %32
    • Slide and lift the hinge caps off the display hinges.
  33. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screw: passo 42, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screw: passo 42, imagem 2 %32
    • Remove the screw that secures the wireless-card bracket to the wireless card.
  34. Dell Alienware 13 R2 Display Assembly Replacement, Disconnect the Antenna Cables: passo 43, imagem 1 %32
    • Disconnect the antenna cables from the wireless card.
    • Turn the computer over and open the display.
  35. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Antenna Cables: passo 45, imagem 1 %32
    • Remove the antenna cables from the routing guides on the display hinges.
  36. Dell Alienware 13 R2 Display Assembly Replacement, Disconnect the Display Cable: passo 46, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Disconnect the Display Cable: passo 46, imagem 2 %32
    • Lift the connector latch and disconnect the display cable from the system board.
  37. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Display Cable: passo 47, imagem 1 %32 Dell Alienware 13 R2 Display Assembly Replacement, Remove the Display Cable: passo 47, imagem 2 %32
    • Remove the display cable from the routing guides on the display hinges.
  38. Dell Alienware 13 R2 Display Assembly Replacement, Disconnect the Logo-Board Cable: passo 48, imagem 1 %32
    • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
  39. Dell Alienware 13 R2 Display Assembly Replacement, Remove the Screws: passo 49, imagem 1 %32
    • Remove the screws that secure the display assembly to the computer base.
    • Lift the display assembly off the computer base.
  40. Dell Alienware 13 R2 Display Assembly Replacement, Align the Screw Holes: passo 51, imagem 1 %32
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  41. Dell Alienware 13 R2 Display Assembly Replacement, Replace the Screws: passo 52, imagem 1 %32
    • Replace the screws that secure the display hinges to the computer base.
  42. Dell Alienware 13 R2 Display Assembly Replacement, Routing the Logo-Board Cable: passo 53, imagem 1 %32
    • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
  43. Dell Alienware 13 R2 Display Assembly Replacement, Route the Cable: passo 54, imagem 1 %32
    • Route the display cable through the routing guides on the display hinge.
  44. Dell Alienware 13 R2 Display Assembly Replacement, Slide the Display Cable: passo 55, imagem 1 %32
    • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
    • Route the antenna cables through the routing guides on the display hinges.
  45. Dell Alienware 13 R2 Display Assembly Replacement, Adhere the Adhesive Tapes: passo 57, imagem 1 %32
    • Adhere the adhesive tapes that secure the antenna cables to the system board.
    • Connect the antenna cables to the wireless card.
    • Replace the screw that secures the wireless-card bracket to the wireless card.
  46. Dell Alienware 13 R2 Display Assembly Replacement, Align the Screw Holes: passo 62, imagem 1 %32
    • Align the screw holes on the hinge caps with the screw holes on the display hinges.
    • Replace the screws that secure the hinge caps to the display hinges.
Conclusão
Terrence15
Membro desde: 12/18/17
79.243 Reputação
Autoria de 441 guias
Equipe
RampUP America, Inc. Membro de RampUP America, Inc.
Community
Membros da 42
Autoria de 1.989 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 405
