Introdução
In this tutorial, we will be showing you how to replace the Dell Alienware 13 R2's base panel.
Ferramentas
Peças
Nenhum componente especificado.
Loosen the captive screws that secure the base panel to the computer base.
Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
Disconnect the battery cable from the battery-cable connector.
Turn the computer over.
Press and hold the power button for 5 seconds to ground the system board.
Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
Tighten the captive screws that secure the base panel to the computer base.
Quase terminado!
Linha de Chegada
