Introdução
In this guide, we will show you how to remove and replace the Power-Button Board from the Dell Alienware 13.
O que você precisa
Remove the small access panel using a heavy duty spudger.
Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
Using the pull tab, disconnect the solid-state drive cable from the system board.
Remove the screws that secure the solid-state drive assembly to the computer base.
Lift the solid-state drive assembly off the computer base.
Make sure the screws are off the solid-state assembly.
Slide the new solid-state drive into the solid-state drive assembly.
Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
Replace the screws that secure the solid-state drive assembly to the computer base.
Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
Remove the screws that secure the palm-rest assembly to the computer base.
Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
Turn the computer over and open the display as far as possible.
Using a plastic scribe, pry up along the edges of the palm-rest assembly.
Lift the connector latch and disconnect the power-button board cable from the system board.
Remove the Keyboard.
Remove the power-button board.
Remove the status-light board.
Remove the touchpad.
Replace the touchpad.
Replace the status-light board.
Replace the power-button board.
Replace the keyboard.
Connect the power-button board cable to the system board.
Align the palm-rest assembly on the computer base and snap it into place.
Close the display and turn the computer over.
Replace the screws that secure the palm-rest assembly to the computer base.
Connect the keyboard cable and the keyboard-backlight cable to the system board.
Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
Peel the touchpad cable and status-light cable off the keyboard bracket.
Remove the screws that secure the keyboard to the palm-rest assembly.
Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
Replace the screws that secure the keyboard to the palm-rest assembly.
Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
Replace the screws that secure the keyboard bracket to the palm-rest assembly.
Adhere the touchpad cable and status-light cable to the keyboard bracket.
Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
Lift the connector latch and disconnect the power-button board cable from the power-button board.
Remove the screw that secures the power-button board to the palm-rest assembly.
Lift the power-button board off the palm-rest assembly.
Slide the power-button board cable into the power-button board connector and press down the latch to secure the cable.
Align the screw hole on the power-button board with the screw hole on the palm-rest assembly.
Replace the screw that secures the power-button board to the palm-rest assembly.
