Introdução
Use this guide to replace the fan in a Dell Adamo 13 laptop computer.
You may need to replace your laptop’s fan if your laptop freezes up at times, your keypad is excessively hot or odd noises are coming from the laptop. If there is no air coming from the exhaust ports then that may also be a bad sign.
There are no special skills or tools needed to complete this guide.
Before beginning, be sure to completely power off your device.
O que você precisa
Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
Using the Phillips #0 screwdriver, remove two 2 mm screws securing the fan to the motherboard.
Remove the fan from the motherboard.
