Ir para o conteúdo principal
Dell AC511 Hanger Replacement
O que você precisa
  1. Dell AC511 Hanger Replacement, Front Panel: passo 1, imagem 1 %32 Dell AC511 Hanger Replacement, Front Panel: passo 1, imagem 2 %32 Dell AC511 Hanger Replacement, Front Panel: passo 1, imagem 3 %32
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Hanger Replacement: passo 2, imagem 1 %32 Dell AC511 Hanger Replacement: passo 2, imagem 2 %32
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Hanger Replacement: passo 3, imagem 1 %32 Dell AC511 Hanger Replacement: passo 3, imagem 2 %32
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Hanger Replacement, Hanger: passo 4, imagem 1 %32 Dell AC511 Hanger Replacement, Hanger: passo 4, imagem 2 %32
    • The speakers do not have to have been removed for this step, though it may make it easier.
    • Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
    • We accidentally removed some of the rubber lining the inside along with the hanger. Use a razor to cut it off before removing the hanger.
Conclusão
William Cook
Membro desde: 03/19/24
653 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 197
