Ir para o conteúdo principal
Dell Inspiron 15-7569 Motherboard Replacement
O que você precisa
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: passo 2, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: passo 2, imagem 2 %32 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: passo 2, imagem 3 %32
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: passo 3, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 3, imagem 2 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 3, imagem 3 %32
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: passo 4, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 4, imagem 2 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 4, imagem 3 %32
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: passo 5, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: passo 6, imagem 1 %32 Dell   Inspiron  15-7569 Motherboard Replacement: passo 6, imagem 2 %32
    • Gently remove the motherboard from the device.
Conclusão
Matthew Clements
Membro desde: 10/03/17
546 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S5-G4, Walkup Fall 2017 Membro de USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,536
