Ir para o conteúdo principal
Dell Inspiron 15-7569 Battery Replacement
O que você precisa
  1. Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, imagem 2 %32 Dell   Inspiron  15-7569 Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, imagem 1 %32 Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, imagem 2 %32 Dell   Inspiron  15-7569 Battery Replacement, Battery: passo 2, imagem 3 %32
    • Unscrew the (4) four screws surrounding the battery with a Phillips #0 screwdriver.
    • Unplug the cord connected to the battery and remove the battery.
Conclusão
5 outras pessoas executaram este guia.
Matthew Clements
Membro desde: 10/03/17
546 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S5-G4, Walkup Fall 2017 Membro de USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
Membros da 4
Autoria de 6 guias
Um comentário
Thanks Matthew,
This was a huge help for me. It took just a few minutes, but I spent some time brushing & blowing out the fan & heatsink. Only difference from the instructions is that there are only 2 screws to remove the battery. The other 2 are removed when removing the case. I am grateful for these videos because, otherwise, one is likely to remove extra screws & miss the hidden ones on some products.
Thanks,
Kev
kevs - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 30
Duração total: 6,277
