Ir para o conteúdo principal
Decorative Light Fixture Lightbulb Replacement
O que você precisa
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: passo 1, imagem 1 %32
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: passo 2, imagem 1 %32 Decorative Light Fixture Lightbulb Replacement: passo 2, imagem 2 %32
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: passo 3, imagem 1 %32
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: passo 4, imagem 1 %32 Decorative Light Fixture Lightbulb Replacement: passo 4, imagem 2 %32
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: passo 5, imagem 1 %32
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: passo 6, imagem 1 %32 Decorative Light Fixture Lightbulb Replacement: passo 6, imagem 2 %32
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: passo 7, imagem 1 %32 Decorative Light Fixture Lightbulb Replacement: passo 7, imagem 2 %32
    • Hold onto the fixture, and screw it back in with the screwdriver.
Linha de Chegada
Jordan Parry
Membro desde: 03/30/21
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 180
