Ir para o conteúdo principal
DeWalt_D26451 Brake Replacement
O que você precisa
  1. DeWalt_D26451 Brake Replacement, Pad: passo 1, imagem 1 %32 DeWalt_D26451 Brake Replacement, Pad: passo 1, imagem 2 %32 DeWalt_D26451 Brake Replacement, Pad: passo 1, imagem 3 %32
    • Please wear safety glasses while completing this replacement guide.
    • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
    • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
  2. DeWalt_D26451 Brake Replacement: passo 2, imagem 1 %32 DeWalt_D26451 Brake Replacement: passo 2, imagem 2 %32
    • Turn the disc pad over and remove the loosened screws.
    • When the screws are removed, the disc pad will come off of the sander.
  3. DeWalt_D26451 Brake Replacement, Brake: passo 3, imagem 1 %32
    • Please wear safety glasses while completing this repair guide.
    • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
  4. DeWalt_D26451 Brake Replacement: passo 4, imagem 1 %32
    • After the T20 torx bolts have been removed, remove the disc pad from the sander.
  5. DeWalt_D26451 Brake Replacement: passo 5, imagem 1 %32
    • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 33
Ao todo: 2,657
