Ir para o conteúdo principal
DeWalt DWE4011 Carbon Brushes Replacement
O que você precisa
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: passo 1, imagem 1 %32
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: passo 2, imagem 1 %32
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: passo 3, imagem 1 %32 DeWalt DWE4011 Carbon Brushes Replacement: passo 3, imagem 2 %32
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: passo 4, imagem 1 %32
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: passo 5, imagem 1 %32
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: passo 6, imagem 1 %32 DeWalt DWE4011 Carbon Brushes Replacement: passo 6, imagem 2 %32
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
Conclusão
Congratulations! To put your device back together, simply reverse the above steps.
Kiera Sloan
Membro desde: 04/03/19
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 19
Duração total: 1,677
