Introdução
Is your DeWalt Reciprocating Saw having trouble with the shaft not sliding correctly? This guide will show you how to expose the DWE305 shaft and how to lubricate it or replace it if needed. You will need is an iFixit Precision Bit Driver, a #2 Phillips Screwdriver, a Torx T20H bit, and a Torx T25H bit to complete this task. For lubrication, you can use any saw lubricant.
O que você precisa
Remove the seven 3/4" Button Head Torx Security screws out of the handle with the Torx T20H bit and IFixit Precision Bit Driver.
Use a #2 Phillips Screwdriver to remove the large black screw at the shoe of the device or the black plastic housing.
