Ir para o conteúdo principal
DeWalt DW997 Drill Chuck Replacement
O que você precisa
  1. DeWalt DW997 Drill Chuck Replacement, Drill Chuck: passo 1, imagem 1 %32 DeWalt DW997 Drill Chuck Replacement, Drill Chuck: passo 1, imagem 2 %32 DeWalt DW997 Drill Chuck Replacement, Drill Chuck: passo 1, imagem 3 %32
    • Open the chuck jaws to the largest diameter. Remove the interior chuck screw using the T20 Torx screwdriver.
    • The chuck screw is reverse, or left-hand, threaded, which means you will need to unscrew it clockwise.
  2. DeWalt DW997 Drill Chuck Replacement: passo 2, imagem 1 %32
    • Insert the Allen wrench into the chuck jaws and tighten the jaws down on the wrench.
  3. DeWalt DW997 Drill Chuck Replacement: passo 3, imagem 1 %32
    • Hit the Allen wrench with a mallet or hammer to loosen and remove the chuck.
    • Hit the Allen wrench from above. Chuck spindle threads are conventional and loosen counter-clockwise.
  4. DeWalt DW997 Drill Chuck Replacement: passo 4, imagem 1 %32
    • Remove the chuck from the drill.
    • Check chuck and chuck mount for damages or debris.
    • If replacing chuck, attach new chuck and check functionality.
    • If clearing debris from a jam, make sure chuck mount is clear before reaataching the chuck and checking functionality.
Conclusão
5 outras pessoas executaram este guia.
7 comentários
If Allen wrench loosens the truck clockwise as written wouldn’t you be hitting it the other way ? Not sure if I’m not understanding correctly or reading something wrong. Thank you
Jan M - Responder
I agree with Jan. This does not make sense to me and i have been twisting this stupid thing for 3 days.
Bridgette Elliott - Responder
Your comment ‘The chuck screw is reverse threaded, which means you will need to unscrew it counterclockwise. ‘ is nonsense.
A normal screw is counterclockwise to unscrew.
What you meant to say was
‘The chuck screw is reverse threaded, which means you will need to unscrew it clockwise. ‘
You might also like to add the the screw is often coated with loctite and very difficult to remove. A high quality tool and plenty of force may be required to remove this screw.
dasdasdas - Responder
I think the clockwise thing wasn’t that hard to understand, but personally, my chuck screw was actually quite easy to remove so it wasn’t a problem for me
J .Healy -
https://studio.youtube.com/video/Vx37F9q...
Here’s a short video on how to fix a chuck on drill. The screw that holds the chuck to the drill broke and needed to be extracted, and replaced.
alejandropenagarcia - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 148
Últimos 30 dias: 832
Duração total: 79,187
