Ir para o conteúdo principal
DeWalt DW920 Rotational Switch Replacement
O que você precisa
  1. DeWalt DW920 Rotational Switch Replacement, Disassembly: passo 1, imagem 1 %32
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Rotational Switch Replacement: passo 2, imagem 1 %32
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Rotational Switch Replacement: passo 3, imagem 1 %32
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Rotational Switch Replacement, Rotational Switch: passo 4, imagem 1 %32
    • Locate the rotational switch
  5. DeWalt DW920 Rotational Switch Replacement: passo 5, imagem 1 %32
    • Carefully release the connection between the rotational switch and the motor assembly. This should be done carefully to ensure that the switch connection switch on the assembly is not damaged.
  6. DeWalt DW920 Rotational Switch Replacement: passo 6, imagem 1 %32
    • Once the switch is freed from the assembly, firmly grip it between two fingers and lift it straight out of the drill frame.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron MacKinnon
Membro desde: 04/06/16
241 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
Membros da 2
Autoria de 6 guias
Um comentário
Everything looks good on this guide, good job!
DankMemerino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,368
