Ir para o conteúdo principal
DeWalt DW920 Motor Replacement
O que você precisa
  1. DeWalt DW920 Motor Replacement, Disassembly: passo 1, imagem 1 %32
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: passo 2, imagem 1 %32
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: passo 3, imagem 1 %32
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: passo 4, imagem 1 %32
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: passo 5, imagem 1 %32
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: passo 6, imagem 1 %32
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Conclusão
Stephen Rada
Membro desde: 03/11/16
433 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 828
