Ir para o conteúdo principal
DeWalt DW920 Lock Switch Replacement
O que você precisa
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: passo 1, imagem 1 %32
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: passo 2, imagem 1 %32
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: passo 3, imagem 1 %32
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: passo 4, imagem 1 %32
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: passo 5, imagem 1 %32 DeWalt DW920 Lock Switch Replacement: passo 5, imagem 2 %32
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Conclusão
Stephen Rada
Membro desde: 03/11/16
433 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 8-2, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-2, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G2
Membros da 2
Autoria de 6 guias
Um comentário
This guide was descriptive and easy to follow. Good job!
DankMemerino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 281
