Ir para o conteúdo principal
DeWalt DCS380 Trigger assembly Replacement
O que você precisa
  1. DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: passo 1, imagem 1 %32 DeWalt DCS380 Trigger assembly Replacement, DeWalt DCS380 Grip Disassembly: passo 1, imagem 2 %32
    • Remove the battery before dissasembly.
    • Remove the M3x16mm T10 screw from the back of the grip. Keep it separate from the rest of the grip screws
    • Remove the six M3.63x19 T15 screws from the grip.
  2. DeWalt DCS380 Trigger assembly Replacement: passo 2, imagem 1 %32 DeWalt DCS380 Trigger assembly Replacement: passo 2, imagem 2 %32 DeWalt DCS380 Trigger assembly Replacement: passo 2, imagem 3 %32
    • Remove the top half of the grip.
    • Turn the saw over and locate the power connectors to the motor.
    • Use needle nose pliers to remove the spade connectors. Take care not to grab the wires on removal, only the end of the spade terminal.
    • Note the polarity for the power connectors and be sure they are not reversed on reassembly.
  3. DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: passo 3, imagem 1 %32 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: passo 3, imagem 2 %32 DeWalt DCS380 Trigger assembly Replacement, Trigger assembly: passo 3, imagem 3 %32
    • Take note of the position of the battery tension spring and safety switch before removal.
    • Lift the trigger assembly out of the grip.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 32
Duração total: 1,060
