Ir para o conteúdo principal
DeWalt DCF885 Selector Switch Replacement
O que você precisa
  1. DeWalt DCF885 Selector Switch Replacement, Battery: passo 1, imagem 1 %32
    • Press the battery release button at the top of the battery.
  2. DeWalt DCF885 Selector Switch Replacement: passo 2, imagem 1 %32
    • Pull the battery away from the tool.
  3. DeWalt DCF885 Selector Switch Replacement, Motor Assembly: passo 3, imagem 1 %32
    • Remove the eight 18 mm Torx Security #10 screws.
  4. DeWalt DCF885 Selector Switch Replacement: passo 4, imagem 1 %32
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. DeWalt DCF885 Selector Switch Replacement: passo 5, imagem 1 %32
    • Disconnect the connector from the motor assembly.
  6. DeWalt DCF885 Selector Switch Replacement: passo 6, imagem 1 %32
    • Pull the motor away from the brush assembly.
  7. DeWalt DCF885 Selector Switch Replacement, Brush Assembly: passo 7, imagem 1 %32
    • Lift the brush assembly out of the drill case.
  8. DeWalt DCF885 Selector Switch Replacement: passo 8, imagem 1 %32
    • Pull the armature assembly apart from the brush ring assembly.
  9. DeWalt DCF885 Selector Switch Replacement: passo 9, imagem 1 %32
    • Pry the two circled connectors apart from the brush ring assembly.
  10. DeWalt DCF885 Selector Switch Replacement: passo 10, imagem 1 %32
    • The brush assembly is now removed from the drill body.
  11. DeWalt DCF885 Selector Switch Replacement, Switch Assembly: passo 11, imagem 1 %32
    • Pull the switch assembly up and out of the drill case.
  12. DeWalt DCF885 Selector Switch Replacement, Selector Switch: passo 12, imagem 1 %32
    • Pull the selector switch out from the outer case.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 703
