Ir para o conteúdo principal
DeWalt DC970 Drill Assembly Replacement
O que você precisa
  1. DeWalt DC970 Drill Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Drill Assembly Replacement: passo 2, imagem 1 %32
    • Remove battery from drill.
  3. DeWalt DC970 Drill Assembly Replacement, Drill Assembly: passo 3, imagem 1 %32 DeWalt DC970 Drill Assembly Replacement, Drill Assembly: passo 3, imagem 2 %32
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Drill Assembly Replacement: passo 4, imagem 1 %32
    • Lay the drill on its side and gently lift the top half off it.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Hamel
Membro desde: 03/10/16
633 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-2, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-2, Catania Spring 2016
UMASSD-CATANIA-S16S4G2
Membros da 3
Autoria de 13 guias
2 comentários
It's actually a torx #10 and obviously, you dont really need a torque wrench, I got mine apart with my pro kit with no problems.
Christopher Porter - Responder
where is the guide?
no mention of the speed selector or any other internal parts
fred rogers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 26
Duração total: 1,919
