Ir para o conteúdo principal
DeWalt DC970 Battery Fuse Replacement
O que você precisa
  1. DeWalt DC970 Battery Fuse Replacement, Battery Fuse: passo 1, imagem 1 %32 DeWalt DC970 Battery Fuse Replacement, Battery Fuse: passo 1, imagem 2 %32
    • Remove the four 13 mm, Torx Security #15 screws found on the bottom of the charger.
  2. DeWalt DC970 Battery Fuse Replacement: passo 2, imagem 1 %32 DeWalt DC970 Battery Fuse Replacement: passo 2, imagem 2 %32
    • Remove the 19 mm, Torx Security #10 screw found in the charger port.
    • Then pull the top of the charger off separating it from the bottom.
  3. DeWalt DC970 Battery Fuse Replacement: passo 3, imagem 1 %32
    • Locate the fuse and pull it out with two fingers.
    • Once you have located the fuse, if you have the replacement fuse just pull the old one out and put the new one in.
    • Replacement fuses can be found in hardware stores.
Conclusão
Antonia Thomas
Membro desde: 03/09/16
318 Reputação
Autoria de 1 guia
Equipe
Um comentário
Can i get some help in locating the fuse in mt dcb 112 dewalt battery charger i cant found it
bigboyf232 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 56
Últimos 30 dias: 346
Duração total: 15,061
