Ir para o conteúdo principal
DeWalt D28110 Power Switch Replacement
O que você precisa
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: passo 1, imagem 1 %32
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: passo 2, imagem 1 %32 DeWalt D28110 Power Switch Replacement: passo 2, imagem 2 %32
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: passo 3, imagem 1 %32
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: passo 4, imagem 1 %32
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: passo 5, imagem 1 %32
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: passo 6, imagem 1 %32
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, imagem 1 %32 DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, imagem 2 %32 DeWalt D28110 Power Switch Replacement, Power Switch: passo 7, imagem 3 %32
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: passo 8, imagem 1 %32 DeWalt D28110 Power Switch Replacement: passo 8, imagem 2 %32 DeWalt D28110 Power Switch Replacement: passo 8, imagem 3 %32
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: passo 9, imagem 1 %32 DeWalt D28110 Power Switch Replacement: passo 9, imagem 2 %32 DeWalt D28110 Power Switch Replacement: passo 9, imagem 3 %32
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: passo 10, imagem 1 %32 DeWalt D28110 Power Switch Replacement: passo 10, imagem 2 %32
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Conclusão
3 outras pessoas executaram este guia.
Kean Wee
Membro desde: 01/22/15
495 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-6, Maness Winter 2015 Membro de Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
Membros da 5
Autoria de 7 guias
Um comentário
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 34
Duração total: 5,607
