Ir para o conteúdo principal
DeWALT Hammer Drill DW511 Brush Replacement
O que você precisa
  1. DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: passo 1, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: passo 1, imagem 2 %32 DeWALT Hammer Drill DW511 Brush Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Brush Replacement: passo 2, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 2, imagem 2 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 2, imagem 3 %32
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: passo 3, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement, Power Cord: passo 3, imagem 2 %32
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Brush Replacement: passo 4, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 4, imagem 2 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Brush Replacement: passo 5, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 5, imagem 2 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 5, imagem 3 %32
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Brush Replacement: passo 6, imagem 1 %32
    • With both wires free, the power cord is free from the trigger body.
  7. DeWALT Hammer Drill DW511 Brush Replacement, Brushes: passo 7, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement, Brushes: passo 7, imagem 2 %32 DeWALT Hammer Drill DW511 Brush Replacement, Brushes: passo 7, imagem 3 %32
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. DeWALT Hammer Drill DW511 Brush Replacement: passo 8, imagem 1 %32 DeWALT Hammer Drill DW511 Brush Replacement: passo 8, imagem 2 %32
    • With a pair of blunt nose tweezers, grab the red wire.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,257
