Introdução
Unfortunately, this issue occurs often with De Longhi ECAM machines. The expansion chamber is sealed very poorly, and therefore, the problem is difficult to fix. Here's how you can try sealing the expansion chamber with a piece of household rubber.
Keep the screws well sorted, they have different lengths.
O que você precisa
Remove all attachments such as water tank, pulp drawer, brew group.
Turn the machine with the back facing you.
Remove five Torx T20 security screws.
Push the side panel back about 1.5 cm.
Lift off the panel.
The following compononents are exposed:
Heater
Expansion chamber
Gear drive
Steam valve
The leak is easy to recognize from the traces of lime under the heater.
from a defective pressure relief valve in front of the heater
from a leaking steam valve
from the upper brew piston if it is defective/leaky
Work the steps in reverse order to reassemble your device.
9 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
20 comentários
Als Dichtung eignet sich Silikonschlauch Außen 3mm x Innen 2mm hervorragend. Ein Stück von 15-20cm ist ausreichend. Wichtig ist ja vor allem der untere Bereich.
Can you please post a link to a gasket that fits ? Amazon or similar?
Ok; do you think it would be better to cut the hose in the direction of the length, in order to wrap the other piece of plastic? or it has to be put in the slot as it is?
Use it, as it is. I myself took a normal rubber band from the kitchen and it worked.
VauWeh -
