Introdução
This piece can be particularly hard to remove. For the last step pliers may be used (and may possibly allow you to replace the press earlier in the guide), but in order to ensure no damage is done using your hands is preferable.
O que você precisa
Flip open the top panel to reveal water reservoir.
Grab the water reservoir by the handle and lift out.
Flip the device on its head.
Using the Phillips #2 screwdriver, unscrew the four 12 mm screws found at each corner of the bottom panel.
Lift the panel off or flip the device over and let the panel drop out.
Flip the device on its head, front end facing you.
Using the Phillips #2 unscrew the two 52 mm screws found underneath the top portion of the device.
Pinch the two sides of the top of the coffee press to unlatch.
Push down into the device as you pinch.
7 outras pessoas executaram este guia.
