Pular para o conteúdo principal
Introdução
Designed as a low cost tablet for students in India, Datawind's Ubislate 7CI sells for about $35, to students in India, with the price subsidized by the government. The device is 7.2 by 4.8 by .4 inches (HWD) and weighs 11.2 ounces.
Peças
Nenhum componente especificado.
  1. Be sure to repair your device on a clean surface so you are less likely to lose small parts.
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Run your prying tool along the front edge of the device to pop off the front cover. Once the halves are separated, your device should look like this.
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Use your prying tool to pop the speaker out from its housing.
    • Use your prying tool to pop the speaker out from its housing.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Use a soldering iron to remove the speaker from its contact points.
    • Use a soldering iron to remove the speaker from its contact points.
  6. Solder your new speaker to the same contact points as before.
    • Solder your new speaker to the same contact points as before.
  7. Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  8. Put the two halves back together. Push down on the edges until you hear them click into place.
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Conclusão
Uma outra pessoa concluiu este guia.
Mekides
Membro desde: 20-10-2014
40 reputação
3 Guias de autoria
Equipe
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 198
