Ir para o conteúdo principal
Datawind Ubislate 7ci Rear Facing Camera Replacement
O que você precisa
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: passo 1, imagem 1 %32
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: passo 2, imagem 1 %32 Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: passo 2, imagem 2 %32
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: passo 3, imagem 1 %32 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: passo 3, imagem 2 %32
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: passo 4, imagem 1 %32 Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: passo 4, imagem 2 %32
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: passo 5, imagem 1 %32 Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: passo 5, imagem 2 %32
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: passo 6, imagem 1 %32
    • Press the back cover of the tablet on firmly until it clicks
Conclusão
Mekides
Membro desde: 10/20/14
40 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 283
