Ir para o conteúdo principal
Datawind Ubislate 7ci Battery Replacement
O que você precisa
  1. Datawind Ubislate 7ci Battery Replacement, Battery: passo 1, imagem 1 %32 Datawind Ubislate 7ci Battery Replacement, Battery: passo 1, imagem 2 %32
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: passo 2, imagem 1 %32 Datawind Ubislate 7ci Battery Replacement: passo 2, imagem 2 %32 Datawind Ubislate 7ci Battery Replacement: passo 2, imagem 3 %32
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: passo 3, imagem 1 %32 Datawind Ubislate 7ci Battery Replacement: passo 3, imagem 2 %32 Datawind Ubislate 7ci Battery Replacement: passo 3, imagem 3 %32
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: passo 4, imagem 1 %32 Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: passo 4, imagem 2 %32
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: passo 5, imagem 1 %32 Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: passo 5, imagem 2 %32
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
Conclusão
6 outras pessoas executaram este guia.
Mekides
Membro desde: 10/20/14
40 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G3
Membros da 3
Autoria de 6 guias
2 comentários
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Responder
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 9,032
