Ir para o conteúdo principal
Daisy Model 10 Carbine Cocking Lever Replacement
O que você precisa
  1. Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: passo 1, imagem 1 %32 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: passo 1, imagem 2 %32 Daisy Model 10 Carbine Cocking Lever Replacement, Removing Screws: passo 1, imagem 3 %32
    • Make sure the safety is on!
    • Place the carbine with the saddle ring and leather thong facing upwards.
    • Locate the screw head on the cocking lever.
    • There should be one on either side of the saddle ring and one on the cocking lever assembly.
    • Place a #2 Phillips Screwdriver in the 11/16ths of an inch, matte black screw on the cocking lever assembly. Twist with a counter-clockwise motion.
    • Completely remove the screws.
    • Be wary of the black washers on the other side of the Carbine. Be sure to keep track of them once they fall out after the screws are removed
  2. Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: passo 2, imagem 1 %32 Daisy Model 10 Carbine Cocking Lever Replacement, Removing the Lever: passo 2, imagem 2 %32
    • Remove the cocking lever by placing your dominant hand’s fingers through the cocking lever handle.
    • With your fingers in the handle, slide the lever towards the butt of the carbine.
    • Finally, pull the cocking lever and carbine in opposite directions to replace the cocking lever.
Conclusão
Timothy Gachot
Membro desde: 10/12/14
237 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-20, Maness Fall 2014 Membro de Cal Poly, Team 6-20, Maness Fall 2014
CPSU-MANESS-F14S6G20
4 Membros
Autoria de 5 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 2,462
