Ir para o conteúdo principal
Daewoo DWC LDC1412S Water pump replacement Replacement
O que você precisa
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: passo 1, imagem 1 %32
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 2, imagem 1 %32 Daewoo DWC LDC1412S Water pump replacement Replacement: passo 2, imagem 2 %32
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 3, imagem 1 %32
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 4, imagem 1 %32 Daewoo DWC LDC1412S Water pump replacement Replacement: passo 4, imagem 2 %32
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 5, imagem 1 %32
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 6, imagem 1 %32
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: passo 7, imagem 1 %32
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
Conclusão
hellotheworld
Membro desde: 12/06/14
191 Reputação
Autoria de 1 guia
Um comentário
Thanks, this saved me heaps of money!!!
Brendan Innes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 43
Duração total: 2,712
