Ir para o conteúdo principal
DYMO LabelPOINT 100 Battery Replacement
O que você precisa
  1. DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: passo 1, imagem 1 %32 DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: passo 1, imagem 2 %32
    • Slide the battery cover release button.
    • Remove battery cover.
  2. DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, imagem 1 %32 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, imagem 2 %32 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: passo 2, imagem 3 %32
    • Remove all six Triple A batteries.
    • If applicable, pull on the black ribbon to release all six Triple A batteries at the same time.
    • Be careful not to damage any of the spring terminals when removing the batteries.
Conclusão
To reassemble your device, follow these instructions in reverse order. If applicable, make sure to set the black ribbon first for future disassembly.
Mike Dam
Membro desde: 09/25/14
201 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-2, Mcgee Fall 2014 Membro de USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,310
