Ir para o conteúdo principal
DWFP55130 Regulator spring Replacement
O que você precisa
  1. DWFP55130 Regulator spring Replacement, Remove regulator knob: passo 1, imagem 1 %32
    • Unscrew and remove the black plastic regulator knob. While unscrewing, it will reach a stop and will keep like cannot unscrew further. Just break through the stop and unscrew to completely remove
  2. DWFP55130 Regulator spring Replacement, Remove plunger actuator: passo 2, imagem 1 %32
    • Use needle nose pliers to remove the plunger.
  3. DWFP55130 Regulator spring Replacement, Use Philips #3 (large) screw driver: passo 3, imagem 1 %32
    • Very gently unscrew the valve with a Philips #3 screwdriver. Take care not to destroy the plastic part
  4. DWFP55130 Regulator spring Replacement, Remove plastic valve: passo 4, imagem 1 %32
    • Use needle nose pliers to pull plastic valve assembly out
  5. DWFP55130 Regulator spring Replacement, Replace broken screw: passo 5, imagem 1 %32
    • Replace screw if broken. Photo is not of the original spring. The original spring had corroded and broken into 50 pieces. The spring doesn’t have to be a perfect fit, just has to hold the part in place. The original spring was approx 6mm wide, 20mm tall and 0.5mm thickness wire.
  6. DWFP55130 Regulator spring Replacement, Reassemble: passo 6, imagem 1 %32
    • Carry out steps in reverse to reassemble compressor and you’re done
Conclusão
Imran Latif
Membro desde: 02/08/23
158 Reputação
Autoria de 1 guia
4 comentários
do you know the replacement part numbers just in case?
myke - Responder
The replacement parts are not listed in the manual and not available for sale. Hence this workaround.
Imran Latif - Responder
what type of spring did you replace it with?
Gaeilge 6 - Responder
Random screw I found from a 3D printer part. Size and shape were both different than the original spring. As long as the dimension are similar to 6mm wide and 20mm tall, it would work. The spring I used was not 6mm by 2omm but close enough that it worked.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 34
Duração total: 190
