Ir para o conteúdo principal
DROCON Ninja Casing Replacement
O que você precisa
  1. DROCON Ninja Casing Replacement, Battery: passo 1, imagem 1 %32 DROCON Ninja Casing Replacement, Battery: passo 1, imagem 2 %32 DROCON Ninja Casing Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: passo 2, imagem 1 %32 DROCON Ninja Casing Replacement, Casing: passo 2, imagem 2 %32 DROCON Ninja Casing Replacement, Casing: passo 2, imagem 3 %32
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: passo 3, imagem 1 %32 DROCON Ninja Casing Replacement: passo 3, imagem 2 %32
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: passo 4, imagem 1 %32 DROCON Ninja Casing Replacement: passo 4, imagem 2 %32 DROCON Ninja Casing Replacement: passo 4, imagem 3 %32
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 138
