Ir para o conteúdo principal
DOSS SoundBox Motherboard Replacement
O que você precisa
  1. DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 1 %32 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 2 %32 DOSS SoundBox Motherboard Replacement, DOSS SoundBox Grille Removal: passo 1, imagem 3 %32
    • Use a small plastic opening tool to gently lift the side of the grille.
    • Gently slide the tool to the front of the speaker.
    • Repeat the process on the bottom of the grille.
    • Gently pull the grille off of the speaker enclosure.
    • Pry with caution, for the grille is fragile.
    Pergunte ao FixBot
  2. DOSS SoundBox Motherboard Replacement, Speaker: passo 2, imagem 1 %32 DOSS SoundBox Motherboard Replacement, Speaker: passo 2, imagem 2 %32
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
    Pergunte ao FixBot
  3. DOSS SoundBox Motherboard Replacement: passo 3, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 3, imagem 2 %32
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
    Pergunte ao FixBot
  4. DOSS SoundBox Motherboard Replacement: passo 4, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 4, imagem 2 %32
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
    Pergunte ao FixBot
  5. DOSS SoundBox Motherboard Replacement, Battery: passo 5, imagem 1 %32 DOSS SoundBox Motherboard Replacement, Battery: passo 5, imagem 2 %32
    • Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
    • Use a magnetic mat to prevent the loss of screws.
    Pergunte ao FixBot
  6. DOSS SoundBox Motherboard Replacement: passo 6, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 6, imagem 2 %32
    • Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
    • Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
    Pergunte ao FixBot
  7. DOSS SoundBox Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
    • Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
    • Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
    Pergunte ao FixBot
  8. DOSS SoundBox Motherboard Replacement: passo 8, imagem 1 %32
    • De-solder the connections from the battery to the circuit board.
    • If you do not already have a replacement battery, you can purchase one here.
    Pergunte ao FixBot
  9. DOSS SoundBox Motherboard Replacement, Motherboard: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Follow the steps leading up to the actual battery removal, but do not actually remove the battery.
    • Remove the two 3/32" screws that attach the motherboard to the battery compartment using a JIS #00 screwdriver.
    • Use your fingers or a pair of tweezers to remove the clip holding the ribbon connector in place. The connector is indicated with an orange marker.
    • Be sure not to apply excessive force on the ribbon connector, as it can break.
    • Find the speaker connector, indicated by a yellow circle, and using your fingers disconnect it.
    Pergunte ao FixBot
  10. DOSS SoundBox Motherboard Replacement: passo 10, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 10, imagem 2 %32
    • Locate and remove the two 3/32" screws, indicated by red markers, that fix the motherboard to the speaker enclosure.
    Pergunte ao FixBot
  11. DOSS SoundBox Motherboard Replacement: passo 11, imagem 1 %32 DOSS SoundBox Motherboard Replacement: passo 11, imagem 2 %32 DOSS SoundBox Motherboard Replacement: passo 11, imagem 3 %32
    • Using the plastic opening tool, gently begin to pry the circuit card away from the speaker enclosure.
    • There is adhesive on the top of the motherboard, use caution while prying to avoid breakage.
    • Using your fingers, you can now remove the motherboard.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
6Comentários do guia
Cassandra, the million dollar question is dWhere can i buy the motherboard for the SiundBox Doos.
please let me know at rubenalexander2611@hotmail.com, ahora todo lo mandan de la china please, a ver si me das una pagina web.
Ruben Diaz - Responder Compartilhar
As Cassandra said before,,,,WHere we can find the parts??? is it any possibilities ?
bunker1312@gmail.com
bunker1312 - Responder Compartilhar
Where to buy your motherboard for doss torch Bluetooth speaker
smoothjobbrian - Responder Compartilhar
Ffs, Where do you get the board? Pretty useless writeup if there's no known location to aquire parts.
Christopher Cox - Responder Compartilhar
I have taken the motherboard out. Where can I purchase another one as I don't see any link for that?
Paul Doran - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 20
Últimos 30 dias: 106
Ao todo: 6,357
