Ir para o conteúdo principal
DOPO 10.1 Tablet Screen Replacement
O que você precisa
  1. DOPO 10.1 Tablet Screen Replacement, Screen: passo 1, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement, Screen: passo 1, imagem 2 %32 DOPO 10.1 Tablet Screen Replacement, Screen: passo 1, imagem 3 %32
    • Remove back case of tablet by taking spudger tool to lift the back plate.
  2. DOPO 10.1 Tablet Screen Replacement: passo 2, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 2, imagem 2 %32
    • With caution, unplug speakers from back case of tablet.
  3. DOPO 10.1 Tablet Screen Replacement: passo 3, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 3, imagem 2 %32
    • Remove battery
    • Grab and apply light pressure to battery to release it from the back
    • Place off to the side carefully. Be sure not to disconnect cables from motherboard
  4. DOPO 10.1 Tablet Screen Replacement: passo 4, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 4, imagem 2 %32 DOPO 10.1 Tablet Screen Replacement: passo 4, imagem 3 %32
    • Locate where the cameras are attached to motherboard
    • Now release and remove them from motherboard
    • Take camera out and place off to side
  5. DOPO 10.1 Tablet Screen Replacement: passo 5, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 5, imagem 2 %32 DOPO 10.1 Tablet Screen Replacement: passo 5, imagem 3 %32
    • Remove motherboard
    • To do this you will have to unscrew a total of 5 .25in phillips head screws
  6. DOPO 10.1 Tablet Screen Replacement: passo 6, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 6, imagem 2 %32 DOPO 10.1 Tablet Screen Replacement: passo 6, imagem 3 %32
    • Remove back metal piece.
    • Use plastic pry tool and go around the edges lightly and pop it off.
  7. DOPO 10.1 Tablet Screen Replacement: passo 7, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 7, imagem 2 %32 DOPO 10.1 Tablet Screen Replacement: passo 7, imagem 3 %32
    • Using a plastic opening tool, remove the back screen pieces from the back.
  8. DOPO 10.1 Tablet Screen Replacement: passo 8, imagem 1 %32 DOPO 10.1 Tablet Screen Replacement: passo 8, imagem 2 %32
    • Using the plastic pry tool remove metal frame.
  9. DOPO 10.1 Tablet Screen Replacement: passo 9, imagem 1 %32
    • Take the iFixit iOpener and place it on the glue
    • This will release the glass from the plastic frame
  10. DOPO 10.1 Tablet Screen Replacement: passo 10, imagem 1 %32
    • Carefully remove glass. If glass is already broken use gloves to remove glass.
Conclusão
Michael
Membro desde: 01/21/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 5-2, Brown Winter 2015 Membro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 1,786
