Ir para o conteúdo principal
DJI Spark Internal GPS Replacement
O que você precisa
  1. DJI Spark Internal GPS Replacement, Propellers: passo 1, imagem 1 %32
    • Push down on the propeller that is being replaced.
    Just a warning, I just tried this guide and it is missing tons of steps, so be careful when you try yourself.
    MisterGuy’s Channel - Responder
  2. DJI Spark Internal GPS Replacement: passo 2, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 2, imagem 2 %32
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 1 %32 DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 2 %32 DJI Spark Internal GPS Replacement, Battery: passo 3, imagem 3 %32
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 1 %32 DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 2 %32 DJI Spark Internal GPS Replacement, Lid: passo 4, imagem 3 %32
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
    The middle two screws appear to have their hex holes plugged with clear plastic.
    Basil Yokarinis - Responder
    How do you remove it?
    MontesDesigns -
  5. DJI Spark Internal GPS Replacement: passo 5, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 5, imagem 2 %32 DJI Spark Internal GPS Replacement: passo 5, imagem 3 %32
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Internal GPS Replacement, GPS: passo 6, imagem 1 %32 DJI Spark Internal GPS Replacement, GPS: passo 6, imagem 2 %32
    • Identify the GPS module on the motherboard.
    • The GPS module will be labeled as ‘DJI G116’.
  7. DJI Spark Internal GPS Replacement: passo 7, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 7, imagem 2 %32
    • Remove the four 6.0 mm Phillips #000 screws holding the GPS module to the motherboard.
    GPS module ribbon cable ineed it please tell me some body where should i find
    manzoorsp67 - Responder
  8. DJI Spark Internal GPS Replacement: passo 8, imagem 1 %32 DJI Spark Internal GPS Replacement: passo 8, imagem 2 %32
    • Pick up the GPS module.
    • Carefully disconnect the GPS module ribbon cable from the motherboard.
    • Remove the GPS module.
Conclusão
Amelia Hagberg
Membro desde: 10/21/19
445 Reputação
Autoria de 3 guias
Equipe
5Comentários do guia
How About Spark's Wifi can't find?
Mark Ryan Fontelar - Responder
GPS module ribbon cable is broken where can i buy?
please if some one have it send it to me
i will pay u
manzoorsp67 -
hey, i have a site where you can buy it from.
Abubakar Atif -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 2,187
