Ir para o conteúdo principal
DJI Spark Cooling Fan Replacement
O que você precisa
  1. DJI Spark Cooling Fan Replacement, Propellers: passo 1, imagem 1 %32
    • Push down on the propeller that is being replaced.
  2. DJI Spark Cooling Fan Replacement: passo 2, imagem 1 %32 DJI Spark Cooling Fan Replacement: passo 2, imagem 2 %32
    • Twist the propeller until it feels loose.
    • Pull on it until it comes off.
  3. DJI Spark Cooling Fan Replacement, Battery: passo 3, imagem 1 %32 DJI Spark Cooling Fan Replacement, Battery: passo 3, imagem 2 %32 DJI Spark Cooling Fan Replacement, Battery: passo 3, imagem 3 %32
    • Flip the drone over.
    • Grip the left and right sides of the battery.
    • Slide firmly forward until it pops out.
  4. DJI Spark Cooling Fan Replacement, Lid: passo 4, imagem 1 %32 DJI Spark Cooling Fan Replacement, Lid: passo 4, imagem 2 %32 DJI Spark Cooling Fan Replacement, Lid: passo 4, imagem 3 %32
    • Remove the four 1.5mm Hex screws.
    • Remove the two 1.5mm Hex screws near the camera head.
    • You may need to remove plastic nubs from the hex screws using a spudger first.
  5. DJI Spark Cooling Fan Replacement: passo 5, imagem 1 %32 DJI Spark Cooling Fan Replacement: passo 5, imagem 2 %32 DJI Spark Cooling Fan Replacement: passo 5, imagem 3 %32
    • Hold the drone so the lid is facing up.
    • Insert the plastic opening tool into the side of the drone.
    • Slide the tool around the perimeter until you can lift the top off.
  6. DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, imagem 1 %32 DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, imagem 2 %32 DJI Spark Cooling Fan Replacement, Cooling Fan: passo 6, imagem 3 %32
    • Remove the fan.
    • It is attached to the motherboard with several pieces of adhesive.
  7. DJI Spark Cooling Fan Replacement: passo 7, imagem 1 %32 DJI Spark Cooling Fan Replacement: passo 7, imagem 2 %32
    • Trace the fan wires to the side of the panel.
    • Unplug the wire from its connector.
Conclusão
Uma outra pessoa concluiu este guia.
Uzochi Anyanwu
Membro desde: 10/21/19
408 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team S1-G7, Botvin Fall 2019 Membro de UMass Dartmouth, Team S1-G7, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G7
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 1,346
