Ir para o conteúdo principal
DJI Phantom Propeller Replacement
O que você precisa
  1. DJI Phantom Propeller Replacement, Open the Battery Compartment: passo 1, imagem 1 %32 DJI Phantom Propeller Replacement, Open the Battery Compartment: passo 1, imagem 2 %32 DJI Phantom Propeller Replacement, Open the Battery Compartment: passo 1, imagem 3 %32
    • Press down on battery door release tab to flip the battery door open.
  2. DJI Phantom Propeller Replacement, Remove the Battery: passo 2, imagem 1 %32 DJI Phantom Propeller Replacement, Remove the Battery: passo 2, imagem 2 %32 DJI Phantom Propeller Replacement, Remove the Battery: passo 2, imagem 3 %32
    • Pull out the battery pack.
    • Avoid pulling on the battery wires, excess stress may break the wires, damage the power connectors, or crack the internal solder joints.
  3. DJI Phantom Propeller Replacement, Disconnect the Battery: passo 3, imagem 1 %32 DJI Phantom Propeller Replacement, Disconnect the Battery: passo 3, imagem 2 %32
    • Pull the two halves of the XT60 power connector apart.
    • It's a tight fit, so be careful not to hit your drone or yank on the cables when it releases!
  4. DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: passo 4, imagem 1 %32 DJI Phantom Propeller Replacement, Identifying Silver and Black Collets: passo 4, imagem 2 %32
    • Silver-topped propeller collets unscrew counter-clockwise
    • Black-topped propeller collets unscrew clockwise
  5. DJI Phantom Propeller Replacement, Unscrewing Silver Collets: passo 5, imagem 1 %32 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: passo 5, imagem 2 %32 DJI Phantom Propeller Replacement, Unscrewing Silver Collets: passo 5, imagem 3 %32
    • For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
    • Once free, unscrew and remove the collet.
  6. DJI Phantom Propeller Replacement, Unscrewing Black Collets: passo 6, imagem 1 %32 DJI Phantom Propeller Replacement, Unscrewing Black Collets: passo 6, imagem 2 %32 DJI Phantom Propeller Replacement, Unscrewing Black Collets: passo 6, imagem 3 %32
    • For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
  7. DJI Phantom Propeller Replacement, Remove the Propeller: passo 7, imagem 1 %32 DJI Phantom Propeller Replacement, Remove the Propeller: passo 7, imagem 2 %32 DJI Phantom Propeller Replacement, Remove the Propeller: passo 7, imagem 3 %32
    • Gently press down the motor shaft and lift the propeller up to remove it.
Conclusão
David Hoyt
Membro desde: 04/09/10
4.053 Reputação
Autoria de 41 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 1,486
