Introdução
This guide will show you how to remove and replace the motherboard of the DJI Phantom 4 Advanced Remote Controller.
Before you begin:
- Please make sure to completely power off the the controller prior to any replacements.
- Please read the guide before any replacements in order to familiarize yourself with the process.
O que você precisa
Remove the four screws with a Torx T8 screwdriver to access the back con board.
Disconnect ribbon tabs 1,2,5,8G, and 3.
Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
Then remove the plugs
2 comentários
Do you know here can i buy a main board for phantom 4 advanced remote controller?
I would like to know too, can’t find one anywhere
