Ir para o conteúdo principal
DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement
O que você precisa
  1. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 2, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 2, imagem 2 %32
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 3, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 3, imagem 2 %32
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 4, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 4, imagem 2 %32
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 5, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 5, imagem 2 %32
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: passo 6, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: passo 6, imagem 2 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Motherboard: passo 6, imagem 3 %32
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 7, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 7, imagem 2 %32
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 8, imagem 1 %32
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
  9. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement, Control Sticks: passo 9, imagem 1 %32
    • Remove the 10.7 mm Phillips screws using a Phillips #1 screwdriver.
  10. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 10, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 10, imagem 2 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 10, imagem 3 %32
    • Gently remove the Gimbal Wheel control component from the body.
    • Take caution with the fragile wires when removing this component.
  11. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 11, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 11, imagem 2 %32
    • Remove the 4 10.7 mm Phillips screws using a Phillips #1 screwdriver.
  12. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 12, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 12, imagem 2 %32
    • Gently remove the Control Stick component.
    • Take caution with small and fragile wires to avoid breaking them.
  13. DJI Phantom 4 Advanced Remote Controller Control Sticks Replacement: passo 13, imagem 1 %32
    • Repeat step 9 through 12 to remove the other Control Stick.
Conclusão
Equipe
IUPUI, Team S1-G1, Harley Summer 2019 Membro de IUPUI, Team S1-G1, Harley Summer 2019
IUPUI-HARLEY-SU19S1G1
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 984
