Ir para o conteúdo principal
DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement
O que você precisa
  1. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 2, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 2, imagem 2 %32
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 3, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 4, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 4, imagem 2 %32
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 5, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 5, imagem 2 %32
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: passo 6, imagem 1 %32 DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement, Back Buttons: passo 6, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the four screws on the inside of the panel. That will allow you to remove the buttons by gently lifting them with your hands.
  7. DJI Phantom 4 Advanced Remote Controller Back Buttons Replacement: passo 7, imagem 1 %32
    • Remove back buttons and replace with new ones.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 433
