Ir para o conteúdo principal
DJI Phantom 3 Advanced Landing Gear Replacement
O que você precisa
  1. DJI Phantom 3 Advanced Landing Gear Replacement, Battery: passo 1, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement, Battery: passo 1, imagem 2 %32
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Landing Gear Replacement: passo 2, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 2, imagem 2 %32
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, imagem 2 %32 DJI Phantom 3 Advanced Landing Gear Replacement, Landing Gear: passo 3, imagem 3 %32
    • Turn the phantom upside down.
    • Remove the eight 7.5mm long 3mm screws, securing the landing gear to the body of the quadcopter, with a T-8 screwdriver.
  4. DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, imagem 2 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 4, imagem 3 %32
    • Remove the rubber spacer in the landing gear by pushing the spacer out of the slot with your finger.
  5. DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, imagem 2 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, carefully separate the two pieces of plastic of the landing gear.
    • Be careful not to break the wire attached, as this is your receiver antenna.
  6. DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, imagem 1 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, imagem 2 %32 DJI Phantom 3 Advanced Landing Gear Replacement: passo 6, imagem 3 %32
    • Feed the wire and attached plastic through the hole in the landing gear.
Conclusão
7 outras pessoas executaram este guia.
Quinn Tirpak
Membro desde: 10/06/16
319 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-2, Livingston Fall 2016 Membro de Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
Membros da 3
Autoria de 12 guias
Um comentário
I have a single coax cable in my landing gear. the gear broke and the wire tore off the connector. How do I fix this?
Art - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 3,804
