Ir para o conteúdo principal
DJI Phantom 3 Advanced Cover Replacement
O que você precisa
  1. DJI Phantom 3 Advanced Cover Replacement, Battery: passo 1, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement, Battery: passo 1, imagem 2 %32
    • With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
    • Remember to disarm and power down your quadcopter before beginning any disassembly.
  2. DJI Phantom 3 Advanced Cover Replacement: passo 2, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement: passo 2, imagem 2 %32
    • Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
    • With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
  3. DJI Phantom 3 Advanced Cover Replacement, Cover: passo 3, imagem 1 %32
    • Turn the Phantom 3 Advanced upside down.
  4. DJI Phantom 3 Advanced Cover Replacement: passo 4, imagem 1 %32
    • Remove the four 7mm long 2mm screws with a T-6 screwdriver.
    • There is one screw per arm, located at the tip of the arm.
  5. DJI Phantom 3 Advanced Cover Replacement: passo 5, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement: passo 5, imagem 2 %32
    • Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
    • There are two 5mm screws on each arm.
  6. DJI Phantom 3 Advanced Cover Replacement: passo 6, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement: passo 6, imagem 2 %32
    • Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
    • There is one screw on each arm located near the landing gear.
  7. DJI Phantom 3 Advanced Cover Replacement: passo 7, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement: passo 7, imagem 2 %32 DJI Phantom 3 Advanced Cover Replacement: passo 7, imagem 3 %32
    • Carefully flip the phantom back over with the motors facing up.
    • Peel back the silver stickers from the seam in the cover.
    • Using a plastic spudger, slowly separate the two halves of the plastic shell.
    • This step requires some force, and the plastic will click loudly as the shell separates.
    • Do not fully remove the cover. There is a wire that needs to be detached from the control board before the cover is completely free.
  8. DJI Phantom 3 Advanced Cover Replacement: passo 8, imagem 1 %32 DJI Phantom 3 Advanced Cover Replacement: passo 8, imagem 2 %32 DJI Phantom 3 Advanced Cover Replacement: passo 8, imagem 3 %32
    • Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
    • Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
    • Press the tab on the side of the connector and pull up on the cable.
    • Continue to remove the shell the rest of the way.
Conclusão
10 outras pessoas executaram este guia.
Robert Comstock
Membro desde: 10/06/16
421 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-2, Livingston Fall 2016 Membro de Cal Poly, Team 10-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G2
Membros da 3
Autoria de 12 guias
3 comentários
Great Job Robert! Even the “Phantom Pilots Forum” had no recent recommendations for a disassembly manual, as DJI likes to “Fixit” themselves!
Michael Steinbrecher - Responder
Excellent detailed instructions. Having pictures on procedure makes it idiot proof.
Bolo - Responder
Does this also include the phantom 3 professional too? My understanding is that the only differences between them is the battery charger and the pro is 4k recording vs 1080p.
John D - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 36
Duração total: 4,650
