Introdução
Hi everyone, In this guide, I'll show you how to replace the gimbal assembly or gimbal housing on the DJI Mini 3 Pro drone.
After replacing the gimbal camera, you may need to calibrate your drone, but this cannot be done using the DJI Fly mobile app, you will need to use additional software. How to calibrate the gimbal watch this video tutorial https://youtu.be/mu03HWXplM4
O que você precisa
Instruções em vídeo
To reassemble your device, follow these instructions.
5 outras pessoas executaram este guia.
9 comentários
Does anyone have a source for replacing the little rubber gimbal mounts?
Andre Purdy - Responder
HI there! Does anyone know where I can buy the whole gimbal in USA? I remember seeing it somewhere but cannot find it
gbonilla - Responder
Go to YouTube and check the link to the gimbal assembly in the description below the video
Arty -
mini 3 pro com port not show on device manegar any help.
Limon Khan - Responder
Start trembling during flight after a horizontal stop. At the start, I can hear the gimbal noise from trembling (before taking off). I gently touch it, and it stops. I take off and fly a long distance.
If I stop it or it stops it by signal loss, the trembling starts again. if I never stop it and take gentle curves back, it may work. At abrupt stops, it starts trembling. I bring the drone back to me at 1-meter height. I gently touch the gimbal (without landing), and it stops. Then I fly again (if the battery is low, I land, change the battery, and start again, same steps, every time). I will probably buy a new one, so I can send this to repairs - did not check the guarantee yet.
- no problems during climbing up.
- only on horizontal movements and hard stops (release the lever on the controller).
I will try never to release the lever abruptly and never lose signal (a signal lost could be a hard brake, also)
??? Calibration can stop this strange error ????
Dorin - Responder
