Use this guide to replace a broken propeller of your DJI Mavic Pro Drone.
The propellers of a drone are very important. If the propellers are damaged, your flight may not be successful. Your propellers may need to be replaced if they crack or break when hit by an obstacle because broken propellers can affect the flight of the drone.
There are no tools required to replace the propellers of your drone, however you will need new propellers to replace the broken ones. Either you have bought the propellers separately or it has came with the drone.
Before beginning, make sure that your drone is powered off, do not replace the propellers when the drone is turned on.
To replace the propellers, check to match the propellers with the arm of the drone.
The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
