Ir para o conteúdo principal
DJI Mavic Pro Propeller Replacement
O que você precisa
  1. DJI Mavic Pro Propeller Replacement, Propellers: passo 1, imagem 1 %32 DJI Mavic Pro Propeller Replacement, Propellers: passo 1, imagem 2 %32 DJI Mavic Pro Propeller Replacement, Propellers: passo 1, imagem 3 %32
    • Unfold your Dji Mavic Pro Drone.
  2. DJI Mavic Pro Propeller Replacement: passo 2, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 2, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 2, imagem 3 %32
    • Push down slightly on the propeller you want to remove.
  3. DJI Mavic Pro Propeller Replacement: passo 3, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 3, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 3, imagem 3 %32
    • There are 2 types of propellers on a DJI Mavic Pro drone: 1 with a white circle outline (shown in the image) and 1 without.
    • If the propeller you want to remove has a white outline like shown in the image, then turn the propeller counterclockwise to unlock its position.
  4. DJI Mavic Pro Propeller Replacement: passo 4, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 4, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 4, imagem 3 %32
    • If the propeller you want to remove DOES NOT have a white outline, then turn the propeller clockwise to unlock its position.
  5. DJI Mavic Pro Propeller Replacement: passo 5, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 5, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 5, imagem 3 %32
    • Pull up the propeller to remove it.
  6. DJI Mavic Pro Propeller Replacement: passo 6, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 6, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 6, imagem 3 %32
    • To replace the propellers, check to match the propellers with the arm of the drone.
    • The propeller with a white circle will have to be placed on the arm of the drone with a white outline and the propeller without the white circle will be placed on the arm of the drone without the white outline.
  7. DJI Mavic Pro Propeller Replacement: passo 7, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 7, imagem 2 %32 DJI Mavic Pro Propeller Replacement: passo 7, imagem 3 %32
    • Align the parts outlined with red with the holes on the arm of the drone outlined by the red.
    • Push the propeller down.
  8. DJI Mavic Pro Propeller Replacement: passo 8, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 8, imagem 2 %32
    • If the propeller has NO white mark (circle) then turn the propeller counterclockwise to lock its position.
    • If the propeller has a white mark (circle) then turn the propeller clockwise to lock its position.
  9. DJI Mavic Pro Propeller Replacement: passo 9, imagem 1 %32 DJI Mavic Pro Propeller Replacement: passo 9, imagem 2 %32
    • Check to see if the propeller is properly locked into place by slightly pulling it up.
    • If it is locked, then you can safely fly your drone.
Linha de Chegada
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 31
Últimos 30 dias: 111
Duração total: 4,528
