Ir para o conteúdo principal
DJI Mavic Pro GPS Module Replacement
O que você precisa
  1. DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 1 %32 DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 2 %32 DJI Mavic Pro GPS Module Replacement, Battery: passo 1, imagem 3 %32
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro GPS Module Replacement, Upper Shell: passo 2, imagem 1 %32
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro GPS Module Replacement: passo 3, imagem 1 %32
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro GPS Module Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro GPS Module Replacement: passo 5, imagem 1 %32
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro GPS Module Replacement: passo 6, imagem 1 %32
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro GPS Module Replacement: passo 7, imagem 1 %32
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro GPS Module Replacement, GPS Module: passo 8, imagem 1 %32
    • Flip the upper shell over so the metallic plate is facing up.
    • Remove the two 5mm JIS #00 screws from the metallic plate by turning the screwdriver counterclockwise.
    • If the JIS #00 screwdriver is too small, you may need to use a JIS #0 screwdriver.
  9. DJI Mavic Pro GPS Module Replacement: passo 9, imagem 1 %32
    • Pry the metallic plate up from the upper shell by using a nylon spudger.
    • Remove the metallic plate from the upper shell by lifting the plate up and out.
    • You may hear a popping sound when prying the metallic plate, but no damage will occur.
  10. DJI Mavic Pro GPS Module Replacement: passo 10, imagem 1 %32
    • Use tweezers to remove the GPS Module from the upper shell.
Conclusão
8 outras pessoas executaram este guia.
Kyle Kelser
Membro desde: 10/08/18
634 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G3, White Fall 2018 Membro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 80
Ao todo: 9,937
