Ir para o conteúdo principal
DJI Mavic Pro Front Vision Replacement
O que você precisa
  1. DJI Mavic Pro Front Vision Replacement, Battery: passo 1, imagem 1 %32 DJI Mavic Pro Front Vision Replacement, Battery: passo 1, imagem 2 %32 DJI Mavic Pro Front Vision Replacement, Battery: passo 1, imagem 3 %32
    • Grab both sides of the battery.
    • Pinch the releasing buttons on both sides of the battery.
    • Lift the battery up and out.
  2. DJI Mavic Pro Front Vision Replacement, Upper Shell: passo 2, imagem 1 %32
    • Remove the six 5mm 1.5 Hex screws by turning the screwdriver counterclockwise.
  3. DJI Mavic Pro Front Vision Replacement: passo 3, imagem 1 %32
    • Flip the drone over so that the gimbal is facing up.
    • Remove the two 4mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
    • Remove the two 5mm 1.5 Hex screws near the gimbal case by turning the screwdriver counterclockwise.
  4. DJI Mavic Pro Front Vision Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the two small panel pieces near the gimbal case with the tweezers.
  5. DJI Mavic Pro Front Vision Replacement: passo 5, imagem 1 %32
    • Remove the two 5mm 1.5 Hex screws and two PH000 screws that are under the panel pieces by turning the respective screwdrivers counterclockwise.
  6. DJI Mavic Pro Front Vision Replacement: passo 6, imagem 1 %32
    • Flip the drone back over so the upper shell is facing up.
    • Pry off the upper shell with a nylon spudger.
    • Be careful when prying with the spudger because you could damage the upper shell's plastic tabs.
  7. DJI Mavic Pro Front Vision Replacement: passo 7, imagem 1 %32
    • Remove the white connector at the back of the flight controller board by gently pulling at the base.
  8. DJI Mavic Pro Front Vision Replacement, Gimbal/Camera: passo 8, imagem 1 %32
    • Remove the one 5mm JIS #0 screw from the small micro controller board at the front of the DJI Mavic Pro by turning counterclockwise.
  9. DJI Mavic Pro Front Vision Replacement: passo 9, imagem 1 %32
    • Pull the cord and micro controller board away from the front of the DJI Mavic Pro using tweezers.
  10. DJI Mavic Pro Front Vision Replacement: passo 10, imagem 1 %32 DJI Mavic Pro Front Vision Replacement: passo 10, imagem 2 %32
    • Expose the two small ZIF connectors near the front of the board by removing the plastic coverings.
    • Then, remove the two ZIF connectors under the coverings using a nylon spudger.
  11. DJI Mavic Pro Front Vision Replacement: passo 11, imagem 1 %32
    • Remove two 6mm JIS #00 screws from the plastic board cover at the front of the DJI Mavic Pro.
  12. DJI Mavic Pro Front Vision Replacement: passo 12, imagem 1 %32 DJI Mavic Pro Front Vision Replacement: passo 12, imagem 2 %32
    • Flip the DJI Mavic Pro over.
    • Gently press the latch for the Gimbal cover.
    • Pull the cover off.
  13. DJI Mavic Pro Front Vision Replacement: passo 13, imagem 1 %32 DJI Mavic Pro Front Vision Replacement: passo 13, imagem 2 %32
    • Flip the DJI Mavic Pro back over, with its top side facing up.
    • Remove the two ZIF connectors located behind the plastic covers by using a nylon spudger.
  14. DJI Mavic Pro Front Vision Replacement: passo 14, imagem 1 %32
    • Gently remove the power cable connector located to the left, behind the gimbal board, by pulling up on the white base.
  15. DJI Mavic Pro Front Vision Replacement: passo 15, imagem 1 %32
    • Scrape away the plastic adhesive covering the two 5mm JIS #000 screws connected to the gimbal board.
    • Remove the two 5mm JIS #000 screws from the gimbal board by turning the screwdriver counterclockwise.
  16. DJI Mavic Pro Front Vision Replacement: passo 16, imagem 1 %32
    • Remove the two 7mm JIS #00 screws at the very front of the DJI Mavic Pro by turning the screwdriver counterclockwise.
    • Careful when removing these screws the camera or whatever remains of your camera assembly may drop
  17. DJI Mavic Pro Front Vision Replacement: passo 17, imagem 1 %32 DJI Mavic Pro Front Vision Replacement: passo 17, imagem 2 %32
    • Flip the DJI Mavic Pro over, with the camera facing you.
    • Gently pull the gimbal/camera assembly up and out.
  18. DJI Mavic Pro Front Vision Replacement, Front Vision: passo 18, imagem 1 %32
    • Remove the two 6mm JIS #0 screws by turning counterclockwise.
  19. DJI Mavic Pro Front Vision Replacement: passo 19, imagem 1 %32
    • Remove the front vision piece by pulling the piece up and away from the drone body.
Conclusão
8 outras pessoas executaram este guia.
Kyle Kelser
Membro desde: 10/08/18
610 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S17-G3, White Fall 2018 Membro de Cal Poly, Team S17-G3, White Fall 2018
CPSU-WHITE-F18S17G3
4 Membros
Autoria de 14 guias
4Comentários do guia
What error codes did you get before having to replace this front cameras?
Daniel Rubio Rocamora - Responder
la nacelle de mon drone mavic pro ne fais aucun mouvement quand je l'allume s'il vous plaît quel pourrait être le problème ?
Picharkayo@gmail.com
Pichar Kayo - Responder
it's most likely the ribbon cable 9-dollar fix from Amazon. that would be my first guess
J. Brown - Responder
I have error of forward motion isn’t recognizing how can I fix it please help
Aoldmilkman1 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 70
Ao todo: 7,320
