Ir para o conteúdo principal
DJI Mavic Mini Propellers Replacement
O que você precisa
  1. DJI Mavic Mini Propellers Replacement, Propellers: passo 1, imagem 1 %32 DJI Mavic Mini Propellers Replacement, Propellers: passo 1, imagem 2 %32 DJI Mavic Mini Propellers Replacement, Propellers: passo 1, imagem 3 %32
    • Place the DJI Mavic Mini on a flat surface with the props oriented upwards.
    • For ease of access place the prop arms in the "open" position.
  2. DJI Mavic Mini Propellers Replacement: passo 2, imagem 1 %32 DJI Mavic Mini Propellers Replacement: passo 2, imagem 2 %32 DJI Mavic Mini Propellers Replacement: passo 2, imagem 3 %32
    • Remove the 2.4 mm J000 screw from the damaged propeller.
    • When removing the screws, you may need to apply some pressure to the swivel mount that holds the propellers.
    • Remove the damaged propellers.
  3. DJI Mavic Mini Propellers Replacement: passo 3, imagem 1 %32 DJI Mavic Mini Propellers Replacement: passo 3, imagem 2 %32
    • Keep the 2.4 mm J000 screw from the damaged propeller to use again when fastening on the replacement.
    • While one or both propellers are removed for replacement, it is recommended that you inspect the exposed swivel mount for any debris which may impact drone performance.
    • Additionally, when fastening the replacement propeller make sure that the screw is inserted into the interior hole on the swivel mount.
Conclusão
Chase Smith
Membro desde: 02/22/22
147 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 1-2, Hunter Spring 2022 Membro de Clemson, Team 1-2, Hunter Spring 2022
CLEM-HUNTER-S22S1G2
5 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 1,089
