Introdução
Disassembling the Mavic Mini drone to replace any of the defective parts.
After replacing the motherboard or gimbal camera, you need to calibrate the drone. How to calibrate the DJI Mavic Mini, watch this manual https://youtu.be/mu03HWXplM4
Instruções em vídeo
4 outras pessoas executaram este guia.
4 comentários
Hey, wanted to say thanks for this video. Super helpful. I crashed the eff out of my Mavic Mini and was getting an error 30045, "Gyroscope initialization failed. Restart aircraft." Looks like my ribbon cable that connects the gyroscope chip module to the main board somehow got ripped (or possibly melted through, I was flying in a rather warm climate.) Of course, it's the longest and most complex cable in the drone, so it'll be a job to get it replaced. I'm ordering a new one and going to see if I can switch it out successfully. Thank you!!
Chris Zirker - Responder
Well you didn’t remove the arms, so not a complete breakdown. I can’t get the pins for the arms back in as the spring loading turns the middle section so that when you screw it in they don’t spring open.
kelly - Responder
Thank you for the information. I am able to put off buying a new drone for the time... (Those pesky trees and gravity)
Humanoid Planetearth - Responder
Excellent teardown and build! Very detailed.
And yes - gravity + trees + drone is pesky indeed :)
Knyte - Responder
